FrugalFlyerv2.0
- Oct 29, 2003
- 2,931
- 3,414
WorldTraveler said:I always prefer to see the marketplace decide winners and losers over the legal system***
*** ofcourse that doesn't apply to DL and DAL
Just like ORD-LHR.
Oh, wait, that doesn't fit the narrative .....
of course it does.*** ofcourse that doesn't apply to DL and DAL
Uh that isn't true at all.WorldTraveler said:
uh, you seem to forget that ORD-LHR was not pursued so DL could start LAX-LHR which is operating.
of course it does.
DL has FOUGHT for the right to serve markets which other carriers and governments have attempted to close.
WorldTraveler said:ORD-LHR was a first step toward swapping markets that did not get off the ground but which has now evolved into a number of markets - and I think you know the list.
WorldTraveler said:that may all be true, E, but the real outcome of this route case will be the marketplace where DL has a nearly flawless track record of pushing itself into key AA markets and growing very quickly to parity with AA for the quality of revenue that AA carries.
WorldTraveler said:tell us what DL strength markets ... ... ...
DL has added ... ... ...
btw, here is an article by Ted Reed about DL's LAX-PVG route application ... ... ...
that is precisely the advantage that having stronger Skyteam partners in China will provide DL that its competitors don't have ... ... ...
further, DL has pushed AA into a strategic lose-lose ... ... ...
... ... ... But DL, and not AA and not UA ... ... ...
DL's addition of LAX-PVG means that ... ... ...
DL has clearly shown once again, ... ... ...
DL still is the largest foreign airline in Japan and will still operate more than enough flights to depress yields over the Pacific and in Japan as long as it takes to finish Japan Airlines off once and for all.
Delta's hub at Narita is the smallest and weakest of the airport's three hub airlines - ANA, JAL and Delta. A reinvigorated JAL, freed from some of its legacy costs, plus perennially-focused and well-run ANA, are likely to make for a rough road for Delta's fortunes at Narita going forward."
The trend of the last 15 years tells the tale: Northwest moved from 747s to A330s to, in some cases, 757s, and now Delta is moving some of those A330 markets to even-smaller 767s. They'll just continue to shrink further and further until they just pull out completely, focusing their Narita operation on the massive local market from Japan to the U.S., and focusing their non-Japan Asia strategy on flights from ATL, DTW, SEA, etc. nonstop to PEK, PVG, ICN, HKG, TPE, etc.
