PIT is getting one track of 757s temporarily due to managements lack of staffing for the CLT hangar, 6 757s would end up being parked thru the summer as they keep taking the manpower from the 757s to work all the extra problems with the A330.
somewhere i read "possesion is nine tenths of the law".....we ain't giving it back. B)700UW said:PIT is getting one track of 757s temporarily due to managements lack of staffing for the CLT hangar, 6 757s would end up being parked thru the summer as they keep taking the manpower from the 757s to work all the extra problems with the A330.
Well I would love to agree with you on this but I cant.delldude said:they bid jobs for deicing in pit, heavy does not to deicing, it is a line function, only time heavy is used is when they exhaust the deicing crew and line then it goes to gse then heavy 😉
Seating Capacity via greater Fuselage length....favoring the -300 Seriesrobbedagain said:what is the difference between a B-767-200ER and the -300ER? does the fuel tank make the difference?
Your right!justaumechanic
Posted on Jan 10 2004, 03:23 PM
There is no good reason for CLT to keep blaming the mechanics in PIT for everything that goes on..
It is not like its a big secret when any aircraft comes due for Maintenance. Lack of planning, lack of support, lack of materials, lack of manpower but plenty of management to tell us we are not getting the job done..
JUSTAUMECHANIC:i wasn't aware they were doing the deicing in this manner.i must raise some questions as to how they are doing this IAW the contract?this seems to be against the scope.....after all the contract i beleive says line-gse-then base,right?if they can't fill at line AFTER calling OT they go to gse,then base i believe..so we're screwing the line boys out of ot.justaumechanic said:On top of that PIT BASE covers the De-Ice Pad. No additional headcount was added to PIT Base for De-Ice pad operations.
how many years now has 491 been handling the deicing in PIT?this sounds like a real juicy 'past practice' grievance to me.justaumechanic said:To be honest the Contract is not very specific as to who does the De-Icing.
In the Past in PIT it was always a Line Function.. Like I said as of this year one pad is controlled by the line the other by Base Mtc Hangar 5.
I can tell you how the Base Mtc Pad is working this year. If the pad is activated and we are busy in the hangar they will call OT for the next shift. Go figure this out. But that is how they are doing it. If they can lose the manpower without causing any significant problem in the hangar they will go without OT.
As for the line they have a dedicated crew working the other pad. I do not believe that OT is an issue out there. For the first time since I have been in PIT when the Line Crew has no work they farm them into BASE Mtc.. That I can tell you for a fact I have never ever seen before.. Usually its the other way around. When the line is hurting they far Base Mtc out.
As for the other comment on how the Union runs things in PIT.. Lets not talk about it.. Everyone is pretty much beaten down by what has been going on. Its painful. Franks to busy doing "Other" things. His famous comment on every issue "They can do that".. Its posted all over the base.. He's a puppet to the company.
