Only if you're confident that $60/bbl is the bottom (or so close that it doesn't matter).
But what if it's not the bottom? What if $12/bbl is the bottom? Or $15/bbl? Or even $20/bbl or $30/bbl?
Wouldn't want to be the genius who locks in $60/bbl fuel for long-term if the price of crude falls to half of that long-term.
Don't think it's possible? Check out historical crude prices since 1946. Or since 1973 (since the price pre-embargo was about the same as 1946). Except for short periods (1979-85 and 2003-08), oil has bounced aroung between $10/bbl and about $30/bbl for that entire time. Think it can't happen again? Predict the price of crude correctly, and you'll be nominated for Southwest-Style Sainthood. Predict incorrectly, and your airline will go bankrupt.
How much have you invested in crude oil (or gasoline) futures at $60/bbl? Not me, since history tends to show much lower prices.
Goose, I'm with you on this. All this time we've been told that the cost of oil was driven up because of an increase in demand from India and China, what happend, did they all of a sudden stop wantng the vast amounts of crude they needed.Regardless of the reason, logic tells me there's no way in hell demand for oil has decreased by 50% (basing the figure on price).
It points more to some entity playing "speculator" with the pricing. I read once that Tulsa's Semgroup was responsible for a lot of the speculative pricing run-up but they went belly up - never again did I see that article. If it disappeared like that, there must have been a tad of truth to it.
$40 - $50 per barrel will probably be the bottoming-out point unless some brilliant SOB decides to corner the market again.
The laws of supply and demand go right out the door when you have someone controlling suppy/OPEC/ and whenever they drop production they artifically create a false demand. Then throw Wall St. into the mess and up go prices.
My gut feeling is that once the recession eases, OPEC may manupulate production/supply in such a way that $75-$100 per barrel will be the standard price - similar to what $20-$30 used to be not too long ago.The laws of supply and demand go right out the door when you have someone controlling suppy/OPEC/ and whenever they drop production they artifically create a false demand. Then throw Wall St. into the mess and up go prices.
Good news but; (from Wikepedia)I hope this is not off subject.
The BAKKEN is the largest domestic oil discovery
HOW can this BE? HOW can we NOT BE extracting this… ! ? Because the
democrats, environmentalists and left wing republicans have blocked
all efforts to help America become independent of foreign oil.
While these numbers would appear to indicate a massive reserve, the percentage of this oil which might be extracted using current technology is another matter. Estimates of the Bakken's technically recoverable oil have ranged from as low as 1% — because the Bakken shale has generally low porosity and low permeability, making the oil difficult to extract — to Leigh Price's estimate of 50% recoverable.[10] Reports issued by both the USGS and the state of North Dakota in April 2008 seem to indicate the lower range of recoverable estimates are more realistic with current technology.
The flurry of drilling activity in the Bakken, coupled with the wide range of estimates of in-place and recoverable oil, led North Dakota senator Byron Dorgan to ask the USGS to conduct a study of the Bakken's potentially recoverable oil. In April 2008 the USGS released this report, which estimated the amount of technically recoverable, undiscovered oil in the Bakken Formation at 3.0 to 4.3 billion barrels, with a mean of 3.65 billion.[11] Later that month, the state of North Dakota's report [12] estimated that of the 167 billion barrels of oil in-place in the North Dakota portion of the Bakken, 2.1 billion barrels were technically recoverable with current technology.[/quote]
So yea there is plenty of oil there but if you have to spend more to get it than you can sell it for then its not really an economic option, its just a strategic assett. According to the same article there is plenty of drilling going on and tax incentives are being offered to promote drilling. So the lack of development has more to do with eceonomics than enviornmentalism.
The problem isnt finding oil, its finding cheap easily extractable oil. The oil sands of Canada also have plenty of oil but recovering it is expensive.
What we need to consider is that with all the many uses of petroleum (we need oil for a lot of things besides fuel*),and the harmful enviornmental effects of burning it, we really should continue to develop alternate energy. Wind, solar, nuclear, geothermal, tidal, and hydro should be our primary means of producing electricity thus freeing up oil for other uses and keeping the air we breath cleaner. To me best way to keep our energy costs low is to develop competitive alternates to oil. If we can use non-fossil fuel methods to economically produce electricity we can then use that electricity to produce hydrogen, which when burned produces water. Then we could use less oil for transportation. The production of cheap hydrogen could even help make recovering hard to recover oil cheaper etc. We dont want to limit our mobility and way of life but at the same time we dont want to pollute and alter our enviornment in potentaily catastrophic ways.
* Petroleum is also the raw material for many chemical products, including pharmaceuticals, solvents, fertilizers, pesticides, and plastics; the 16% not used for energy production is converted into these other materials. from Wikipedia
At one time our primary source of fuel was trees, with modern energy demands if that was still the case there wouldnt be many trees left on earth and the air would be very polluted. Then came coal, coal provided a more compact energy source than wood, however it too was dirty. Then came petroleum,even more compact, much cleaner and easier to use than coal but because we use so much of it it's still dirty. Wood, coal , oil, we have always had these things available to us, oil was used by the ancients for lighting, waterproofing and even roadbuilding. Technology helped us develop those resources and improve our living standards. Wind, solar and gravity have also always been with us and can potentially provide us all the energy we need without the harmful enviornmental effects of burning fossil fuels, we just need to develope the technology to make it cheaper than oil. Burning fossil fuels puts tons of pollutants into the air, its time to move on to sources that can provide us cleaner energy.
Its economically good for the short term to see oil dip below $60 a barrel. We all could use a break, our lifestyles have been built around cheap oil, but what happened this past summer should prove as a warning, if we dont get off our dependance on cheap oil, regardless of its source, we are headed for disaster both ecomically and likely enviornmentally.
Demand has not gone down 50%, but the speculators are betting that the demand for petroleum and oil related products will be down for the next several years due to the global recession. Remember, oil is used for more than just transportation fuel. It is also used to make plastics, which is used in almost everything sold in the world today. People across the world are buying less, or will be buying less, due to diminished buying power. I think the bottom of the barrel as far as oil prices is near, but to put an exact dollar figure on it...Regardless of the reason, logic tells me there's no way in hell demand for oil has decreased by 50% (basing the figure on price).
Agreed. That's why this lifelong conservative Republican has always been in favor of higher national gasoline taxes. From 1973 to the present (or 1980 to the present) we should have been adding an annual increment to our national gasoline taxes to encourage conservation.
The CAFE standards have been proven a worthess attempt at micro-management by Congress. A much better solution would have been to raise the price of gas, which would have altered behaviour. Look at the 8% year over year decline in miles driven this past August. Unprecedented reduction in driving in this country.
Had we slowly adjusted to $4/gal or $5/gal gas over the past 30 years or so, we'd have been in a much better position. And the billions raised by a higher gas tax could have been used to improve highways and improve mass transit throughout the country.
