Ok, so if the "padding" is not an increase in block times on flights, can you explain what it is?Exactly. Anecdotal schedule searches comparing block times aren't the issue here. US has admitted to padding the schedules early this year to help the employees win the race. US also admitted that increasing the block times is an expensive way to run an on-time airline and that US is beginning to remove the padding. A few weeks ago, BoeingBoy posted the text of a message from US to the employees about it and now it's been confirmed in none other than The Wall Street Journal.
If the employees can keep up the good work and keep the airline running on time once the padding is removed, then Great!
Most of the people live in the northeast. They don't want to hub through LAS to get from Portland, Maine, to Tampa, Florida.
One way that they could do this is to stop forcing connections through PHL. IMHO they made a tremendous mistake by giving up on PIT instead of using it as a connection hub to feed traffic through the Midwest and to/from the West.
We had a good thing going in PIT, too bad Allegheny County was never really in our corner. They resented our presence when we were there and then have the nerve to ask Doug Parker
to reinstate Europen service.
It was your boy Isom who said it was so expensive.Let's face it, if padding is so expensive, let's think about all the customers that have not misconnected and therefore not needed to be reaccomidated, put up in a hotel, meal vouchers, etc.
Deleted by moderator. See moderator comments, post 24.
I realize that. They don't want to hub through PHL, either, because it usually means lengthy delays on the tarmac.....and that is once they are on the plane. That's why I mentioned PIT. It was the ideal connecting hub for people who had no reason or desire to pass through PHL on their way down to FL. If US could re-direct some of their flights out of the crowded NY/NJ airspace, it would alleviate some of the unnecessary fuel burning.
I personally like the padding. It satisfies a psychological need.![]()
But there are 2 fundamental flaws in US padding its schedules:
1) It's like a Band-Aid in that it makes it easy to cover the wound of lengthy delays due to airport/ATC congestion/staff cutbacks, etc.
2) It gives US an unfair advantage in "On Time Performance" if all airlines do not pad equally.
Given the reality of flying to/from/through PHL, I would rather have the schedules padded than not........but only as an interim solution, and not at the expense of curing the real ailment. "Cheating" is not OK, but honestly trying to fix a problem is. Given all of the cutbacks in flights after the summer, perhaps there will be less of a need for schedule padding, and will give US the breathing room to really turn the operation around.
And taking a quote from WN playbook, planes on the ground don't make money
