407 Driver
- Mar 10, 2003
Nomex, I respond to your question (Re 407 Temp limited) with another question, when does a B2 become Ng limited at altitude and temp? 😀 We all get focused on Torque, who says that it has to be the defining limit, is it not acceptable to be Ng limited, or Temp limited?
I've seen a huge range of C47 engines out there. Some are great, others
:down: are not. In our 7 C-47's, we have about 4 "great's" a couple of average ones, and 2 dogs. I've been told that Standard (or Acro or ?) can do a much better job of building a good engine if they have all the components Vs ..just a turbine?
The question should be...does the aircraft perform to the manufacturers published data? They all do !
I haven't seen the article from Vertical yet, it was shot in the Canmore area, so I doubt that our covert little western-slope operation is featured 🙁
Re: the B2's MGB limits, so what you're saying is that the B2 and 407 are quite close in available power? The 407 with a few % edge.
:down: are not. In our 7 C-47's, we have about 4 "great's" a couple of average ones, and 2 dogs. I've been told that Standard (or Acro or ?) can do a much better job of building a good engine if they have all the components Vs ..just a turbine?The question should be...does the aircraft perform to the manufacturers published data? They all do !
