407 driver or Cyclic monkey, I have a question for you, I dont have a 407 manual at hand but,
maybe you could clear a few things for me on the fuel system in the rocket
If you have a dual transfer pump failure and the fuel trapped in the front tanks can be as high as 135 pds, does that mean the low fuel light that normally comes on around 110 pds will now come on at approx 245 pounds total indicated because the sensor for the low fuel light is in the rear tank.
So I would take the fuel in the front tanks that are unusable and add 110pds? That is approx where I will see the low fuel light? I hope that makes sense.
Thanks and merry xmas to you and Hollywood.
