As350 Problems?
For all those "shadey" Operators out there, call'n into the clients and making panic.... "What are you going to do when all the Astars you are using are grounded?" Well here's to you...We are still flying! Sorry, you know who you are....Sorry, still no work for your MD's or Bells...
T Rex....you mean there is shady operators that would do such a thing?
It's a good tactic, if nothing else works for you I guess.
All I have is a total of 2 hours in an astar, and 1 hour was doing hyd. off, a lot harder than a 206, but still doable. I am not that qualified to comment on the system, but what is the big friggen deal. I am sorry that people have been killed, but was it really the hydraulics. There are so many variables ,as people have stated, that you cant jump to conclusions. We will have to wait and see what the allmighty T.C says and make our judgement from that. I read most all of T.C and N.T.S.B accident reports(Final Reports) and if you will notice, things like LTE, white out, brown out, practice autos, settling with power and the always ever presant-- pilot error ect.... take more lives and cause more accidents than hyd off. All I can say is that given the opportunity to fly one right now, sign me up!!! As for the govt over reacting, we all know that never happens . This is just my opinion, however unqualified it may be. This is a dangerous proffesion, and we all know that, its called calculated risk, thats why we get the big bucks!
Big bucks????????
Shady operators????????
This can't be true..............in our industry ???????
All these rumours have to stop !!!!
Where is Mr Facts when we need him??
I dont think I have even seen a final accident report for hydraulics off in an astar. Rumors, rumors rumors. I guess we'll find out in 1 to 3 years from now.
Randy G:
Just curious :huh: - what is the potential problem with the 205 with 212 blades and dual HYD Sys?
I've flown the standard 205 with Single and Dual Hydraulics and would like to know what difference the 212 blades make.
A no hydraulics auto in a 205 would be an "event" even with 205 blades.
Cheers
Sharkbait
Mr. Facts.............he is around, talked to him yesterday he may make a apperance at ant time so he says 😉 😉 😛
Sharkbait when you have a #2 hyd failure in a 205 with the 212 blades, you can't get the collective all the way down. With 2 of us durn near sitting on it (we are both over 200 lbs) we couldn't get the collective to the bottom. Tq gauge was still showing 16 psi (as you know 100%N2, flat pitch, you should indicate 10-13psi Tq ), someone of a lesser stature may not get it that far down. So if you have the #2 fail, and are unlucky enough to have the donk give up the ghost, you'll most likely bleed off Rrpm until it's beyond recovery. Whoever thought up that system, should have made a truely redundant hyd system. Ensuring that the cyclic, and the collective are powered by both systems.
Cheers
Randy G:
So we are not talking the dual Bell 212 System as installed on late model 205's?
Cyclic, collective, pedals on 1 and only cyclic and collective on 2.
Interesting!
Could you get the pole back up?
Been such a long time since I had the pleasure of driving a 2 by 5. Loved that machine.
Cheers
Sharkbait
PS I think if we don't stop we will have a whole new subject here.
I've heard alot of interesting theories about these hydraulic incidents...
Is anyone in the know about the maintenance schedule for changing hyd fluid and filters for the incident organizations (chc, mnr)?
...still working my own!
T-Rex, it would be wrong of someone to actually call up a customer on this latest round of hearsay, I certainly never talked to anyone. But from your angle, I'd not be spouting it off as a non-issue , We haven't heard the fat lady sing quite yet.....
The boys on justhelicopters are talking of ASB 05.00.43 and the lack of spare parts. Does this affect all 350's? I recall an incident in "the corporation" on a routine 10,000 hr insp that BBX was found to have a crack radiating over 180 degrees !!??
Mag, just because I loose tailbooms, it's no reason for you to try it too ! 😀
Have the problems been on machines with both the Dunlop and the Samm servo's ?
Sharkbait, all of our's have cyclic/pedals on #1, and cyclic/collective on #2. Didn't matter what serial number, since we had them from #30002 (a serial number that Bell tells us doesn't exist) up to almost 297, and they were all the same system.
Bit of a personal question, eh wot ?? :shock: 😛 It's no problem raising the power, but getting it back down is another matter.
Cheers
Ok here's one for ya Randy..... #2 Hydraulics Fail in 205A1 with the govenor in Emergency Gov. mode........ooooohhhhhhhh!!!!! "This ain't going to be pretty!"
407 never in a 1000 years would I call AHL a "shadey op." Hope it's alittle warmer on your side of the rocks these days? Yes, those calls were put in by somebody! Had to deal with the after effect all day! 'Re assurance!' was the quote of the day.
Mag, you going to make it to HAC in Ottawa? I believe I am going there, you?
With the collective forces in the 205 I seem to recall that the twist of the TT straps could be adjusted to lessen the problem.
:elvis: :elvis: :elvis:
