You have done no such thing. I want a dept. by dept. data sheet that compares who outsources what and at what cost in comparison to the other. If you KNOW they are overstaffed then you must have the data available.
All you has said is they have more employees then Delta. That means as much to me as saying Delta has more employees than Comair.........
In other words all you has said is AA is worse than Delta because Delta is Delta. For those of us in the real world it mean jack poop.
Okay....first Rob said they have more airplanes. you added the last part.
second. AGAIN AA and US are in year 1 of the post BK(AA) and merger world. Delta is done. You have to give time for AA to be able to get the same synergies DL now has.
Example, It highly likely that if AA maintenance started doing the CFM56-5 work in-house they will be able to save money like Delta did when they started doing NWs CFM56-5s in-house. Also getting all the employees groups under one contract (vs 2 or 3) and ones seniority list (again v 2 or 3) is going to help AA lower its cost base and produce higher revenues. (and shouldn't cost them any employees) So right now all your doing is comparing apples to butt holes and trying to get people like me, who has 3 degrees in this stuff to buy in. Sorry doesn't work.
because they aren't really merged yet. Given time I fully expect AA to do just like DL and lower its post merger fleet count. The other issue is AA doesn't have a hub like CLE or MEM that I expect them to dump like DL/UA have. Thus its likely they are still going to have a higher fleet count. However they will still be able to balance the network, which should allow for some of the AA Airbus and Boeings on order to park the older airplanes at US. (like DL they have some of the oldest 320s flying)
But again, we are talking about questions that can't even be answered now. Talk to us in 4-5 years if AA is still facing these "issues". Expecting them to be Delta right after their merger when Delta has years to get everything do is a little bit much.
Again, Comparing Delta to AA right now is apples to butt holes. AA gets its few years to merge just like DL did.
I have consistently given you data but you don't want to accept it.
No company gets a 5 year pass on generating revenues on par with its peers because they are going thru a merger.
but you have finally said what I expected all along - that AA would reduce its fleet count - and whether you admit it or not - their headcount as they gain efficiencies from the merger.
I fully recognize and have acknowledged that AA will get to where DL is.
and whether you think AA has no hubs that they could downsize or rationalize, there is plenty of evidence otherwise.
and whether they do or not, AA is simply not generating the revenue growth on par with its peers. Wall Street doesn't care what AA has to cut in order to generate comparable revenues but they do have to get there if they want to be viewed as a viable best in class airline.
you also fail to accept that DL and UA and WN will all be making their own strategic and network changes that will make the bar higher and higher for AA. DL has been carrying the weight of an increasingly less profitable NRT hub for two years now - but DL has managed to be profitable on the Pacific and to grow its system revenue above the legacy carrier average in the process.
by the time AA has a combined res system and can start implementing their strategic plans related to merger efficiencies, DL will have removed 2/3 of the 744 fleet and removed 25% or more of its capacity from Japan, rerouting that capacity to nonstop Japan overflight routes.
DL's performance in NYC and ATL continues to increase. DL's west coast strategies continue to develop.
UA is fixing many of its problems which have left it at the bottom of the industry including rapidly replacing 50 seat jets with large RJs at a rate that is far faster than AA.
WN continues to reshuffle its network to maximize profits and at the same redeploy assets into key AA competitive markets.
so, yes, AA has time to implement its strategic plans but they are still overstaffed compared to their peers and they will have to face an industry which is itself moving forward while much of the competitive efforts are being focused far more at AA markets than those of any other carrier.
