I believe the CF-6 engine is outsourced to General Electric for overhauls.delldude said:i believe your etops problem is on cf-6 powered aircraft..... and is already being addressed by FAA.
[post="243046"][/post]
insp89 said:I believe the CF-6 engine is outsourced to General Electric for overhauls.
[post="243589"][/post]
700UW said:It had everything to do with outsourcing. The problems with the CF-6 are related with a fire loop, which are NOT repaired in-house, they are vendored out.
US even sent QA to the repair facility to get to the bottom of it.
Don't let the facts get in your way.
[post="243595"][/post]
Does General Electric not overhaul the CF-6 engine ?planejane said:I said nothing of repairs. Does U not due general mtc - oil, etc on engines?
[post="243596"][/post]
700UW said:Are you that ignorant?
It had nothing to do with general mtc. After EVERY single flight the oil on the CF-6 engines are checked and recored into the maxi-merlin system, that is mandatory due to the ETOPS on the plane and a logbook entry has to be made.
The problem was with a fire loop that is manufactured and repaired by a vendor, nothing to do with oil levels.
Like I said, keep reaching.
[post="243597"][/post]
700UW said:Glad to see you never let the facts get in your way.
[post="243604"][/post]
In this case, 700 seems to know more than you.planejane said:Answer to first question - No.
Your always trying to imply the any outsourcing will lead to problems. That only U employees know what they are doing. NOT TRUE. I cannot go any further on this matter because of course, you know all.....or should I say, half the facts....
But don't let that get in your way.
[post="243603"][/post]
