Alabama Maintenance Contrator
Mrfish, get off the pipe.
US Airways NEVER had a airbus hit a terminal, yet alone drive by our mechanics. That was NWA.
US has never had a nosegear twist around after being worked on when our own mechanics touched it.
US never lost a cowl, but has had a cowl open in-flight which caused an AD for the whole airbus narrowbody fleet for new latches to be installed.
Don't let the facts get in your way there mr frontier.
So your saying that USAIR is infaliable?????? Post the known in house screw ups buddy, becuase all the carriers have that from time to time. Wait let me visit the FAA accident and incidents page and find errors made by USAIR maintenance, I'll be back!!!!!!
Go ahead mr fish, cant take it when you are shown to be posting things that dont happen?
Funny how you are always bitter towards UA and US fine AMTs at those two airlines.
Please show me the airbus that US Airways Mechanics drove into a concourse.
You posted it, you back it up!
[post="243632"][/post]​
"Never", think again cowboy, remanants were in the AI hsngar in PIT for the longest time.... AD, not! Company policy due to dumbas*es requires verification by another mech to ensure cowls are closed properly. Lav panels do not.
There was a replacement of latches on all carriers who operate narrow body airbus with CFM engines after the incident that happened with the A321 cowling flapping in-flight.
Funny I was in stores at the time and we received and shipped the latches out.
Guess that was all my imagination then huh?
Sorry I don't dump lavs anymore, so try another lame attempt at an insult.
[post="243642"][/post]​
No insult, just pointing out the facts that you are so fond of pointing out. Your issuing out of latches most likeley stemmed from failing the latch tension check that is required by the company. You seem to have an active imagination that I do not need to feed. Propdoc out.
mrfish3726 said:
700,
The mechanics at UAL had the nose gear turned on them MORE THAN ONCE when I worked there. That was a flaw in the Airbus Maintenance Manual not the guys doing the work. No one is infalible EVEN YOU! How many times has USAIR, UniTED, NW, or AW lost engine cowls. How about the USAIR Airbus that your mechanics drove into the concourse, I beleive MORE THAN ONCE. If your QA isn't policing what is happening at your 3rd party maintenance then shame on them. And having worked 3rd party before, to many times the company REP turned down the request for a repair and pencil whipped it himself. It would be interesting to compile a survey or find a source as to how many incidences there are with shitty in house maintenance VS 3rd party. They'd probably run neck to neck!
[post="243627"][/post]​
You're are full of it to Fish!! Having worked at Timco " I KNOW" first hand what goes on there!!! Little young babies, mostly non-A&P mechanics working there!!! :down:
700,
Just eyeballing FAA AGC Quarterly reports, from what I have seen so far, USAIR has had more maintenance violations thrown against them than all the 3rd party facicilties in the USA.
I am going to have fun putting this list together to PROVE to YOU that YOUR #### STINKS JUST LIKE EVERYONE ELSES!
It is just to bad that they only put maintenance or QC down and don't really get down to the nitty gritty of what YOU GUYS F'D UP! Here are a few good ones tough.
US Airways Settles Civil Penalty Case for $75,000
The Federal Aviation Administration has accepted $75,000 from US Airways Inc. to settle a case in which the FAA had alleged that the air carrier had operated a Boeing 737 aircraft in an un-airworthy condition.
In that case, FAA alleged that US Airways had failed to properly classify damage uncovered during a scheduled maintenance check, a condition that required a major repair before the aircraft could be returned to revenue service. US Airways operated the aircraft on approximately 247 flights between February 24 and April 18, 2000.
During the maintenance check, which was done at the carrier's maintenance facility in Pittsburgh, Pennsylvania, a puncture was found in the left-hand elevator upper surface. To prevent such re-occurrences, US Airways has revamped its engineering assessment procedures. US Airways will now review all such assessments to ensure they meet the carrier's maintenance standards and procedures. This announcement is made in accordance with the FAA's practice of releasing information to the public on enforcement actions involving penalties of $50,000 or greater.
FAA Proposes Civil Penalty of $245,000 Against US Airways, Inc.
The Federal Aviation Administration has proposed to impose a $245,000 civil penalty against US Airways, Inc., for allegedly failing to inspect and maintain six Pratt and Whitney PW4000 engines on three Airbus Industrie A330 aircraft in accordance with Federal Aviation Regulations and the air carrier's FAA-approved operations specifications.
FAA alleges that as a result of failing to comply with its continuous airworthiness maintenance program and limitations contained in its operations specifications. US Airways operated the three, A330 aircraft on hundreds of passenger-carrying revenue flights, between June and September 2000 while they were not in compliance with the Federal Aviation Regulations.
US Airways' maintenance program and operations specifications require that a periodic borescope inspection be done on turbojet engines either at 600 cycles or 2,000 flight hours, whichever occurs first. FAA alleges that the air carrier failed to do those internal engine inspections at the required time.
US Airways has implemented a procedure to ensure that the actual number of engine cycles on aircraft used for training flights is recorded in the airline's maintenance computer system. US Airways is also developing ways to automate this procedure.
Operations specifications outline how an individual carrier complies with FAA regulations. They are tailored to meet the unique needs of the individual operator.
US Airways had 30 days from receipt of the proposed civil penalty letter, which was mailed March 12, to respond to the allegations. US Airways requested an informal conference to discuss the proposed civil penalty. That meeting is scheduled in early July.
This announcement is made in accordance with the FAA's practice of releasing information to the public on newly issued enforcement actions involving civil penalties equal to or greater than $50,000.
[post="243633"][/post]​
Hey Catfish, If they showed just half of the ##it that goes on at 3rd. party, they would close all of them. While working at timco I rarely EVER saw the FAA!!!! Something that Timco doesn't have??? PRIDE in owner ship!!!! Those places are nothing but revolving doors..... But U wouldn't know any thing about that now would you???? :shock:
PROPDOC say"Company policy due to dumbas*es requires verification by another mech to ensure cowls are closed properly."
DOC, that was UniTED's solution to the problem also for mechanics forgetting to latch the cowls on the Airbus. If it got opened it got wrote up and verified by two mechanics signatures. There was NEVER an AD issued for the AIRBUS latches at UniTED either. The latches that were on the cowl in the LAX incident went out for examination and were found to be in working order!!!!
700,
I never implied that ALL USAIR or UniTED tech's were bad tech's. But you know just like anywhere else in ANY business you got your good and bad. USAIR and UniTED DO have bad tech's same as the 3rd party, same as here at F9. So don't spout on and on that USAIR doesn't make the same mistakes in maintenance that the 3rd party guys have made. To prove us ALL wrong why not post your 30 day reports on here of aircraft that have been done in house (OVERHAULS) and the ones done at 3rd party. Show us how many re-works, ATB'S, and in genral any QC issues that arise. Probably won't be much difference between the in house or 3rd party I suspect! But proof is in your hands to show us how bad the 3rd party maintenace is on your fleet!
Hey BAJA, I am sure you got your hacks to dude. I worked at Dalfort in TX before and I know what goes on in 3rd party. But then again when I worked at UniTED they had to give A&P's the answers to their stupid little avionics test just so the guy who bought his FCC could get into avionics. Once there, they were hacks!!! Hell when we had the YAW DAMP, FIR-EX, and GOD knows how many other mods going on at once! These guys ran and terminated wiring like they were putting a $50 stereo in their Chevorlet! So don't tell me about HACKS UniTED breed their share of HACKS same as at any company!
[post="243661"][/post]​
U are right US has some hacks too, no doubt, but most airline mechs, at least before the last round of cuts, had pride in their work... Didn't see hardly ant at 3rd. party!!! B)
700UW said:
See you cant back up your diatribe.
You were caught and now you can't climb out of the hole you dug yourself.
Glad to see you never let the facts get in your way.
[post="243604"][/post]​
Hmmmmm...."Attacking", 700?? Hmmmm??? :down:
Fish everything you stated was not done by the mechanics it was management's failure to adhere to the maintenance program.
